Lookout
lookout.exe - runtime error - terminated in unusual way
When attempting to launch Lookout 6.6\lagcc 6-25-12 I get the following:
Runtime error
Program C:\Progr
The application has reqested the Runtime to terminate it in an unusual way.  Please contact the application's support team for more information.
(5,201 Views)
Have you tried re-compiling the source file (.lks)?
(5,190 Views)
Hello, I tried your suggestion and it crashes. It crashes the same way attempting to recompile the .lks file as it does when attempting to launch the .l4p file (crashes). Other .lks files recompile just fine. Any other ideas? Michael
(5,183 Views)
If you ipload the source file I'll try compiling it and see what happens.
(5,161 Views)
OK, they are attached, thanks for your help!
(5,156 Views)
Unfortunately it compiled clean and ran without any errors..
(5,149 Views)
