Lookout
mailer object
Please Help.
I cannot get a successful mailer object connection to an SMTP server.  The only thing logged by the tracefile is [[NEW SEND]] each time a send is attempted.  Note: Tried both host name and IP address for server field in the mailer object and I have verified server allows unauthenticated SMTP by using a copier on the same IP address successfully through the same SMTP server.
Ed
(3,660 Views)
Hi Ed,
I was able to send mail using the Lookout Mailer object.  However, I am on the same network as that of my mail server.
If you have LabVIEW on the machine, or even on the same network, you can use the attached VI to rule out any mail-server issues.
-Khalid
(3,651 Views)
Thanks Khalid for the response.  Turns out it was the darn port-blocking rule on Virusscan Enterprise 8.0 that was giving me the problem!  All set now. I was a little rushed to blame it on Lookout...Robot Sad Oh well...
Message Edited by erblock on 02-16-2006 11:54 PM
(3,649 Views)
