Lookout
miss connection when change my pc
hi,
i build a project in one computer that my driver was modbus tcp/ip and test my connection ,everythings was ok,now,i run this project in another pc ,unfortunately some of the objects(like:knob objects & expression and pot) have not connection,but,some like logical objects have connection.why?
how can i solve this problem?
(5,868 Views)
Are you using the Remote URL / Symblic link conenction?  CHeck that the computer name is not used (\\machinename\ vs \\.\)
Forshock - Consult.Develop.Solve.
(5,858 Views)
i don't use this format(=/machinename/...) but i use symbol link ,and in my project ,there are 1modbus ethernet & 1modbus serial & 1modbus slave .
is the problem ,for this reason?
(5,855 Views)
If it works on one machine, and not the other you have a bad connection.
This could also be a Communications Failure fromt he attached symbolic link.  Is it a different network (IP or Subnet)?
(5,838 Views)
