Lookout
missing fields in citadel
Hi, I am using lookout v5.0. When I try to import ALL the fields from the Citadel database to Excel, I only have these fields as heading in 4 columns
"LocalTime" "UTCTime" "Interval" "Resolution"
and I can´t see any data in the sheet.
Can anyone help me?
thanks
Hector
(3,278 Views)
Hi Hector
                 Thanks for using National Instruments discussion forums. Im not sure about the procedure that you are using to import the information from Citadel to Excel.
Here are some links that might help you in this process:
http://digital.ni.com/public.nsf/websearch/5915049F3BF93935862568C5005E9DF3?OpenDocument
Also I attach you an example  made in labview.
hope this helps and that you can run your application without problems very soon!
regards Smiley Happy
Erwin Franz
Certified LabVIEW Architect, Certified TestStand Developer
(3,249 Views)
