Lookout
modbus write only register
i need to read and write some register in delta inverters with serial modbus (ascii or rtu)
the problem for this product is that the register is not read-only or read-write
but is read-only or write-only, if you try to read this registers the driver generates error
it is possible to configure in lookout some data member in modbus object in order to write it for variation but keeping lookout from reading
               B_N_
Message 1 of 1
(6,041 Views)
