Hello 23r23,
Running the move command from the cmd (DOS prompt) using Lookout's run object would move the files. The following command for example moves the contents of c:\temp to the temp directory on the network machine \\hurricane:
"cmd /c move /y c:\temp\*.* \\hurricane\temp"
/c launches the cmd and then terminates when done
/y suppress the "overwrite" warning if the files already exist
Note that you can move CSV and other files with this. But, not historical data files (from Citadel, i.e., the *.thd) because they are "currently in use." You may want to use the CitadelControl object for archiving the historical data more gracefully.
Hope this helps.
Khalid
