Lookout
multi keystroke search
Please add to the next release of Lookout the multi keystroke search (like it was in 3.8) to the following:
Edit Connections -Select Member – Writable members (Top Left Box)
Edit Connections -Signals – Contents (Bottom Right Box)
Insert Expression – Contents (Right Box)
We spend the majority of our time working with these components and scrolling is brutal if you have several thousand data members in a DataTable with a slow remote connection.  Is there something others are doing that I am missing?  This request goes back to version 4.
(5,528 Views)
It's good suggestion. I can understand it's not easy to locate a datamember in Edit Connections if there are thousands of datamembers.
Ryan Shi
(5,518 Views)
