Lookout
multiple modbus sessions
I need to connect slaves with RS232 port to PC, so each slave will have one PC serial port connected to it. And the protocol is modbus. Will Labview/ OPC support more that one serial port on the PC with modbus protocol?
(4,301 Views)
Are you planning to use LabVIEW or Lookout?  I ask because you've posted this under Lookout forum.
-Khalid
(4,299 Views)
Oops! Labview it is. BTW how do I move it to the right sub forum? Or repost it there?
thanks,
(4,297 Views)
No problem  -- you may want to just repost in the LabVIEW forum.
By the way, and for the record, Lookout can do this i.e., have multiple Modbus Objects via multiple serial ports.
-Khalid
(4,295 Views)
Thanks, will repost it there.
(4,291 Views)
