Lookout
panel object deletion
Hello there,
In Lookout 3.8 I could not delete a panel until the panel was empty. In
Lookout 4.0.1 I've found that this protection no longer exists. In other
words, I am able to delete a panel from the Object Explorer while control
objects and expression displays are on the panel. Is this an intended change
in functionality?
Thanks, JTS
(3,451 Views)
You are allowed to delete panels even if they are not empty in both Lookout
3.8 (build 16) and 4.0.1. What you cannot do is delete objects that are being
displayed in some way on a Panel. For instance, all displays of Pot1 must
be removed from all panels before you can delete Pot1.
(3,451 Views)
