Lookout
possible to use multiple VIs with state chart module?
I'm trying to make an application using state chart module and I have to use at least to VI that I've developped. I'm having problems when I want to define inputs while using the module. All my VI's have stop buttons and the I/O that I need. I have the same problem with the outputs. As seen as I can't define the I/O of my moore type machine I can't neither define the guards and the actions.
Do you if we can use multiple VI with that module or do I have to use the old good case+while state machine technique.
Thanks.
Message 1 of 1
(5,906 Views)
