Lookout
problem with panel dimension
first question
if i set the same panel dimension in revise control panel setting and in panel connection the result is not the same
 for example to have the correct dimension i must set for one pannel
in revise control panel  height 400 and with 630
in panel connection height 440 and width 640
what is the problem ?
second question
it is possible to lock the possibility to move and arrange the panel for the operator ?
(i have set also x and y in connection)
               B_N_
(6,076 Views)
I also notice this weird behaviour. The panel has two sets of parameters for the size. We suggest you to use the panel.width and panel.height to set the size. The help also recommends this way.
I don't find a way to prevent user from moving the panel.
Ryan Shi
(6,052 Views)
