Lookout
"Error saving state file"
I am getting an error that shows up on the alarm screen - it says "Error saving state file:c\program files\national instruments\lookout 5.0\petco.l4t".
Background:  An old XP pro machine running the application died and was replaced with a new Dell, business class PC, Optiplex 360, Win XP Pro sp3, 2.2ghz dual core.
After moving the application and setting up the PC, I get the following message every time it trie to say the state file.
Is this a compatibility problem with the new hardware?
What can I do?
any ideas?
THANKS
Mark
(7,880 Views)
To add what may be a few important points:"  THis is a one-PC application - both development and operator station in one.
I thought I may be having a file permissions problem, so I moved the application files to a shared file folder.  ...same thing
Mark
(7,879 Views)
I don't think it is related to the hardware. Lookout just tries to save a file. Usually this error is about the file permission.
If you save the process, will it save the state file successfully? You can check the last modified time of the file.
Ryan Shi
(7,865 Views)
Edit mode, File->Modify process, try to save a standby state file and input a directory such as d:\. Let's see if it is able to save the file to differenct directory.
Ryan Shi
(7,863 Views)
Ryan,
I just don't understand why, but now it is working.  The only thing I have done since the last post is to restart the application.  It is now saving in the shared file location just fine.
Thanks for your time!
Mark
Mark
(7,855 Views)
Does this machine have an auto-backup feature?
Some backup applications can actually lock the partition, making it read only.
Something to check
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(7,847 Views)
Mike,
Thanks for your input.  No there is no backup program on this PC.
Mark
Mark
(7,840 Views)
