Lookout
"Latchgate" object problem
I have created some additional latchgate objects (4) into a long running process that I programmed about three years ago.  After adding them to my process they work as designed, as long as the process remains open/running.
When you close Lookout and then re-open Lookout and the process the Latchgate object will Latch "ON" before it is supposed too.  If I go into edit mode/object explorer and open the "properties" dialouge box and then close the "properties" dialouge box of each of my 4 latchgates they will function normally, I do not have to make any changes to the logic.
Anybody know what is going on????
(Example of one of the newly created Latchgate objects)
LatchGate_InterlockLockPinA
Turn On:  Fieldpoint1.Sw_StopPinA_Extended<1 and (Sequencer_VertMillingA.D or Sequencer_VertMillingA.E or Sequencer_VertMillingA.I or Sequencer_VertMillingA.J or Sequencer_VertMillingA.K or Sequencer_VertMillingA.L or Sequencer_VertMillingA.O or Sequencer_VertMillingA.S)
Turn Off:  Pb_ResetLockpinA
(5,669 Views)
Do you mean that after you open the lookout process the Latchgate will be ON, but it should be OFF?
Create another expression of Fieldpoint1.Sw_StopPinA_Extended<1 and (Sequencer_VertMillingA.D or Sequencer_VertMillingA.E or Sequencer_VertMillingA.I or Sequencer_VertMillingA.J or Sequencer_VertMillingA.K or Sequencer_VertMillingA.L or Sequencer_VertMillingA.O or Sequencer_VertMillingA.S).  Then reopen the process. See when the Latchgate is unexpectedly "ON", what's the status of that expression. If the expression is False, this behaviour is wrong.
Ryan Shi
(5,659 Views)
Ryan
The "latchgate" does not go high upon starting the process.  The purpose of this latchgate is to monitor the extended position of the stop-pin, during certain states of a programmed "sequencer" object.
State #3(output-C) of the sequencer extends the stop-pin.  The goto-4(output-D) data member of the sequencer is connected to the stop-pin extended switch.    The stop-pin extended switch sends the sequencer to state #4, output-D.
The latchgate will go high when the stop-pin extended switch makes/closes.  The ON expression never "trues".
This will happen every time I reset the latchgate and start the sequencer object,  until I go into edit mode/object explorer and open the properties window for the latchgate(s).  All I have to do is open & close the properties dialouge window for the 4 latchgates and then they will function as designed, until I close the process and reopen it.  Then I have to do it all over again.
Chip Howell
Amtec Corporation
256-319-6210
(5,652 Views)
I'm not able to reporduce it.
If LatchGate turns ON, when ON expression is false, it may be a bug.
Can you make a simple example to show it? If it can be reproduced by a simple process, we can narrow down the problem. Or tell me how you configure the sequencer object and latchgate object, by screenshot or example.
Ryan Shi
(5,635 Views)
