Lookout
runtime report from citadel
Been a while, but here i am again.
I am trying to retrieve the total time a point was active using SQL and Citadel.
Example 1 SQL:
SELECT LocalTime,"ETM{\\Mikedesktop\Server\PumpC\BC}" FROM TRACES WHERE LocalTime >= "2006-05-23" and LocalTime <= "2006-05-23" and Interval = "1"
0 record(s)
Example 2 SQL:
SELECT LocalTime,"ETM{\\Mikedesktop\Server\PumpC\BC}" FROM TRACES WHERE LocalTime >= "2006-05-23" and LocalTime <= "2006-05-24" and Interval = "1"
2 record(s)
5/23/2006   0
5/24/2006   .5313... (12:45:13)
Problem is, that time returned for the 24th is actually for the 23rd! It was on all day the 24th (which shows on the 25th!) so i could test it.
We could make this work with an EXTERNAL VB application, but it is required that we keep it "Lookout".  ActiveX is not wanted, but unless there is a way to make this work, maybe the only way to go...
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
Message 1 of 9
(4,789 Views)
This is just a guess, but have you tried specifying the end time as the same day but also specifying the time as 23:59:59?
WHERE LocalTime >= "2006-05-23" and LocalTime <= "2006-05-23 23:59:59"
-Khalid
Message 2 of 9
(4,767 Views)
Yes, same response, 0 for the 23.
Message 3 of 9
(4,764 Views)
Is it possible that  LocalTime "2006-05-23" has an implied time part of 00:00:00? If so, isn't the period actually less than a full day. (1 sec less?)
It would be interesting to test with an interval other than 1. (ie 00:01:00)
Also the results from a full 24 hour period might work differently.
ie WHERE LocalTime >= "2006-05-23 00:00:00" and LocalTime <= "2006-05-24 00:00:00"
Stated another way, there are 24 hours in one day. But you need to specify 25 hourly times to  specify those 24 intervals.
Bob
Message 4 of 9
(4,749 Views)
Intervals less than 1 day (1 hour or so) give the times for that hour on the 23
from 23 to 24.  But for full 1 day, the previous days end time is on the next day, like ive shown.
And of course, you cant show the current runtime as the day isnt over...
mike
Message 5 of 9
(4,743 Views)
Is the system time in Lookout correct? Object explorer->System->Time.
Ryan Shi
Message 6 of 9
(4,728 Views)
Yes it is correct, as it was on that day also.
Just for more info, i have tried my own vb application, the NI vb example and using the lookout sqlexec/datatable.  All same results.
I was hoping that i wouldnt have to "fake" the times, as this can get very intensive.
Message Edited by Mike@DTSI on 05-30-2006 01:38 PM
Message 7 of 9
(4,725 Views)
I'm a little confused.
The result in example 2 is 5/24/2006   .5313... (12:45:13)
Do you mean it should be 5/23 12:45:13?
If you trace the data in MAX, what's the date for that? 5/23?
Ryan Shi
Message 8 of 9
(4,693 Views)
You got it, if i view the trends data is correct for the 23rd, but using SQL i have to retrieve 2 days to get the data for the 23rd.  To add more to the equation, if i set start day as 5/24 end 5/26, the data for the 24th shows INCORRECTLY, the 24th runtime shows as the 25th.
so rundown
5/23 runtime is on 5/24
5/24 is on 5/25, but 5/24 shows the WRONG DATA which is supposedly the 23rd.
Getting fun aint it 🙂
Message 9 of 9
(4,692 Views)
