Lookout
sens sms
I wohnt to send sms message in NI lookout with siemmens M20 terminal or M35 please help
(4,642 Views)
For this your best bet is the ASCII Object. You can "construct" the SMS message in ASCII and send it using the ASCII Object. You'll use a modem connected to a phone line and send the SMS message to the phone number.
I am not very familiar with the M20 and M35, though.
Khalid 🙂
(4,642 Views)
yes, u can use the ascii object but only if your gsm modem uses ascii format, if ur modem uses PDU format you can use the ascii object too but with some limitations
(4,642 Views)
Look this example may help. Only no more than 70 characters in any language.
(3,804 Views)
