Lookout
slc 5/05 conversion
I developed a process in Lookout 5.1 for a SLC 5/05 using RSLinx.  I now have 6.0 and no longer want to use RSLinx and use the new 5/05 support instead.  What steps do I have to go through to make my old programs run without RSLinx?
(3,217 Views)
Setup the Allen Bradley driver object with the SLC 5/05 ethernet item and the IP address of the PLC. Open the member configuration and enter or Import your alias information. Change alll your PLC connections to look at the new AB Ethernet driver.
(3,212 Views)
