Lookout
sql refresh
I got a problem when I collect data from a MS Sql server database with the Database Connectivity toolset.
The data I get is not all correct.
I got these data
AdjustedQuantityPerExpanded   OrderQuantity   ComponentItemNumber   ComponentItemDescription     TotalQuantityRequired
1                                                         10                        60001929                             CONN SL M 4 LEADED            10
But the correct data should look like this.
3                                                         10                        60001929                             CONN SL M 4 LEADED            30
I have made the two query'es in Access.
With the right one I have made a RefreshLinks before the query.
The question is, how do I make a refresh in Labvview ?
Here is a picture of the funktions I use in labview
I use:
Labview 6.1
Database connectivity toolset 1.0.1
Best regards
Bjarne
(3,627 Views)
Sorry, I put put this question in the wrong forum. It belongs to the Labview forum.
Bjarne
(3,613 Views)
