Lookout
$system.NetworkStatus Error remnant?
I inserted an expression into my panel for \..\$System.NetworkStatus, and it displays "Unable to connect to process manager for data item: \\DIMENSION\Claywood_Server_Process\Exp_Walker_Call..."  The DIMENSION, I believe, refers to a computer name, however that is not the name of the computer this process file is running on.  The Claywood_Server_Process is the name of the process file that is a valid process file on this machine, and the Exp_Walker_Call item is not in this process file, which leads me to believe that this might be a remnant from a previous version.  If so, is there a way to locate how it is pointing to this item so I can fix it?
Werner
Werner Knight
(5,596 Views)
It looks like an object is connecting to \\DIMENSION\Claywood_Server_Process\Exp_Walker_Call.... If the computer, process or item doesn't exist, you will get this error.
Do you see an alarm related to this remote bad URL? If you find this alarm, you will see the object connecting to it.
Another easy way to figure it out is to look into the source file. Open the source file (.lks) by notepad, search it for the DIMENSION. If an object is configured to read that item, you will find it in the source file. And then, try to edit or remote that object in Lookout. I don't suggest you to edit the source file directly.
Ryan Shi
(5,577 Views)
