Lookout
two monitor operation
I have two monitors for an eye test.  The first monitor is control (text size, font, brightness), and the second monitor is used to display the eye chart.  While running the test I would like to set up everything on the control monitor and when I continue with the test, the eye chart should be on the second monitor.
However I have not been able to set up the eye chart on the second monitor unless I drag it over there after the test is started.  Is there a simple way to make the eye chart window go to the second monitor when started up while keeping all the other windows on the control monitor.
Thanks for any help
Bill
(3,465 Views)
Sorry, put this in the wrong location, I'll repost under LabView.
(3,460 Views)
