Lookout
what's the different between "Recipe" and "Recipe Temp" in Alarm area
what's the different between "Recipe" and "Recipe Temp" in Alarm area?
thanks
(3,012 Views)
The "Recipe" area is the default Alarm area for the Recipe object. Any errors associated with this Object would by default be reported under this area.
"Recipe Temp" may be a user-created area. You may want to check your Recipe Object's Database or Datamember Configuration (from the Object menu) to see if there's an alaram area with that name.
If you have not created any user-alarm-areas, make sure you do not have a stray Recipe object with that name.
Hope this helps.
Khalid
(3,012 Views)
