Lookout
windows standby feature disabled after lookout 4.5.1 b18 installation
I am just upgrading my development system - using an HP8510w running Windows XP professional.  Haing the need to support some legacy systems in Lookout 4.5.1, I am having to install this software as well as the more recent Lookout 6.1.  On installing 4.5 only, after the installation the standby feature on the laptop disappeared.  Does anyone have an ideas what might have caused this?  I have tried a number of options, of which I am getting now where.  Any help would be appreciated.
Ian
(6,144 Views)
Did you install the NI Keyboard Driver with Lookout 4.5?  I'm not sure if it is installed with 4.5 by default.
This driver will cause a similar problem. So try to modify the 4.5, if the driver is installed, remove it.
Ryan Shi
(6,128 Views)
