Lookout
.wmf files in Lookout
How to modify the color of an image in .wmf format? I would like to change the color of a Custom representation of a Switch in Lookout 5.0.
(2,988 Views)
Check out the Image Navigator. It not only provides tons of additional images, it also gives you the ability to customize the images also. To access all these wonderful images, click on the Image Navigator button in the Lookout Select Graphic dialog box (which appears any time you insert a custom graphic in a Lookout control, or when you choose Insert»Graphic from the Lookout menu). It is pretty intuitive to use, and you will be creating all kinds of custom colored graphics in short order.
(2,988 Views)
