Lookout
zetron 1730/1732 and lookout to monitor some paging eq.
Looking for a code to work with zetron 1730/1732 and lookout to monitor some paging eq. and transmitters and set a sw to select main to backup
(3,396 Views)
Can you please elaborate what exactly you're trying to accomplish?  Meanwhile, you may want to look at the following NI Example; it uses 1700 and 1716, but I don't see whay it can't be used with your 1730 and 1732s:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3F17556A4E034080020E74861
-Khalid
(3,383 Views)
Thanks for the reply,
I am looking to control the 1732 core outputs at this time.
I am wanting to create a panel that has a l.e.d with each sw that lights when on
I will need 8 switches On / Off on the panel to control the i/o on the Core
one is a rely on the core which i would like to get first..  I need to know how to assign the switch to the address on the core I thought i had it but it does not work
thanks for the link I will take a look
Brent
(3,384 Views)
