MATRIXx
Abort ( core dumped)
my autocode process is terminating while execuating the dac file. i analysed my tpl file by each segment, finally i got to know that there is a segment called gen_systemdata in that i am trying to create a data store structure using for loope.
the problem is it is able to generate only one structure in the for loope, if it goes to second iteration for creating the another structure the autocode process is terminating and geeting a error called Abort( core Dumped).
so i removed the the entire for loope for creating the structures instead i used the declare_structs command it autocoded sucessfully. but my auto coded files are generated with float data type, i understood that we need to enable typecheck option in matrixx, after doing that i got some different error like unknown word size passed in build_fixedtypename.
i am using matrixx 8.1..
Message 1 of 1
(6,155 Views)
