MATRIXx
Can I change the default page size for SYSBUILD?
When I start SYSBUILD it always has a default page size of Letter set, is there any way to change this as most of the blocks I wish to print are to be printed on A3 paper?
Many thanks
Tim
(8,279 Views)
Sorry, I forgot to say I am using MATRIXx 7.1 on Windows 2000.
(8,275 Views)
Hi Tim,
Unfortunately there is no option to change the default print settings for SystemBuild. You must manually select the A3 paper size under File>>Page Setup.
Thanks for the suggestion though, I will pass that on to R&D as a product suggestion for a future release.
Jeff M.
Applications Engineering
(8,248 Views)
