MATRIXx
Controls initiated via mouseup or mousedown
This question pertain to an older version of Matrixx. Build 61mx1411.
Using the interactive annimation, I have defined a 3 position latching switch (mouse down flips the switch and mouse up releases the switch back to nominal).
Graphically the switch works fine. However, my problem is that the switch does not consistantly respond to the mouse up in the value sense. For example, if the switch is connected to an LED indicator, the LED will activate on Mouse Down (on the switch) and the LED will deactivate on Mouse up. This is the condition I desire. However, this is not always the case. Sometimes (seems random) the LED will NOT acctivate on mouse down, but then will activate THEN deactive on mouse up.
(7,133 Views)
Can you post the model? That way I could test it in a newer version of MATRIXx, either 6.3 or 7.1 and see if the behaviour is still there. Also what OS are you using?
Carl L
www.ni.com/matrixx
(7,133 Views)
