MATRIXx
Difference in performance of SBA between Windows and Unix
I am using a  MSF routine which uses SBA to recursively search a sysbld suprerblock and its children to find a specific type block (in this case a ucb). It works fine on both Windows and Solaris Xmath. However, for very large models, there is a huge performance difference. I ran the algorithm on a model containing around 1000 superblock and 10000 blocks. Under Solaris (7.1.5) it takes around 30 seconds while under Windows XP (7.1.6) it takes more than 8 minutes.
Any thoughts on the reason behind this difference.
Farshid
P.S. The MSF file is attached
Message 1 of 1
(7,128 Views)
