MATRIXx
Fatal error: TNT.10049 with Matrixx 6.0.6
After installing a new motherboard in a target system, I started receiving a fatal error message from the target, TNT. 10049. All is fine through the autocode, build, compile, link and download. A soon as I start the controller from the GUI console, the error appears. Host system is running NT4.0, Matrixx 6.0.6 and Pharlap TNT DOS-Extender Ver 8.03. The target motherboard installed is an Intel (Tabor 2). Documentation points to the number of NIStack buffers, but I don't see where or how to change from the default value. Any assistance would be greatly appreciated.
Thank you,
Dave Coulson
Senior Research Engineer
Aeroelasticity Branch/TDT
LaRC NASA, Hampton, VA
(8,261 Views)
Hello Dave;
Can you provide some additional detail. Is the traget system one of the ISI RealSim products such as the AC100 Model C30 or C40, etc.?
Regards;
Marcus Lites, MATRIXx National Sales Manager
P: 972-742-8353
E: marcus.lites@ni.com
http:\\www.ni.com/matrixx
(8,261 Views)
Marcus,
The system is an ISI Realsim C_PC AC100 Model C30 with two PCI-40A carriages installed mounting two IP-HiADC-PCI, two IP-DAC-PCI and one IP-DIG24_PCI modules.
Hope that helps some.
Dave Coulson
(8,261 Views)
