MATRIXx
Freq range for open loop freq response not variable in MatrixX 6.1?
I am using MatrixX build 61mx1411.
I try to create an open loop frequency response ranging from .1 rad/s to 250 rad/s. I alter the max freq default from 10 to 250 and the number of points from 101 to 1000. The bode plot that returns has a freq range from .1 to 10 rad/s. Revising the x axis scale does not show any data above the 10 rad/s value.
Is this a bug? Can a get a patch?
Thanks.
JColich
(7,904 Views)
I'm using 6.2 here, but I realized that the gui form for the open-loop frequency response to be a bit picky on input process. When you modify the parameters, they appear as "buttons" on the form and clicking on these buttons turns them into what appears as an edit field. To complete the parameter modification, one must hit the "Enter" or return key to turn the field back into a "button" form for the parameter to be modified.
(7,904 Views)
Right on !
That was it, Galen.
Thanks for the help.
(7,904 Views)
