MATRIXx
How to redirect standard output/error of a ucb function to matrixx command window
Is there a way to redirect standard output/error of a ucb function to matrixx command window?
I know that the recommended way is to use stdwrt or XmathDisplay commands. However, we have some
libraries that already exists which uses printf calls and I would like to redirect their output
to the matrixx command window.
(7,826 Views)
What you need to do is create a printf function that will print the information into a string, then you can use stdwrt to display it in Xmath.
Then you tell the UCB linking process to compile and link with this version of printf.c
I am including the printf.c that we used to test the function you needed.
Hope this helps.
(7,813 Views)
