MATRIXx
Importing SystemBuild model from MATRIXx v5.0 to v6.2
I am trying to load a SystemBuild file made in MATRIXx v5.0 into v6.2 The error I get says that the file version must be at least SystemBuild v4.0
So, I saved the file in v5.0 just in case it might have been older than that, and I got the same message. I tried generating code and importing that file into new version, but that did not work either.
I also opened SystemBuild catalog in v6.2 and used Load function from there with Advanced option. I can see all the blocks that I am trying to import, but the moment I try to finish loading process, SystemBuild closes completely.
I would appreciate help on this. Thanks
(7,447 Views)
MATRIXx 6 should be able to read models from MATRIXx 5. Is it just one file that is causing problems? It might be one specific superblock that is causing the problems. You could try to save only one or two of the blocks from the hierarchy to see if you can open those.
What operating system are you using?
If you don't mind posting your model you can attach it to your response and I can look at it. Or if you prefer you can email it to matrixx@ni.com.
Carl L
(7,447 Views)
That was a good suggestion. I was actually able to load individual blocks one by one until I found one of them that caused SystemBuild to crash. It had a bug in form of an unidentified superblock. I am not sure how it got there, but once I delete it, everything went fine.
Thanks for your help.
(7,447 Views)
