MATRIXx
Lnx Debugging problem on windows
I am running into problem when trying to debug an lnx program in matrixx  715 on windows XP.
I am using the Visual C++ 6.0 compiler.
This is what i am doing (as per the user's guide example):
oscmd("makelnx -debug myfun.c")
Compiling myfun.c ...
 cl /nologo /MT /Z7 /Od /IC:\PROGRA~1\NATION~1\MATRIXx\mx_71.5\xmath\include /DMSWIN32 /c myfun.c
myfun.c
Linking myfun.exe ...
 link /OUT:myfun.exe /NOLOGO /SUBSYSTEM:windows /INCREMENTAL:no /DEBUG /DEBUGTYPE:cv myfun.obj C:\PROGRA~1\NATION~1\MATRIXx\mx_71.5\xmath\lib\xmath.lib
user32.lib advapi32.lib
Microsoft (R) Program Maintenance Utility   Version 6.00.8168.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
ans (a scalar) =   0
debug myfun
myfun(1+jay)
***A*** Process ./myfun.exe failed to load (system error).
`myfun'(1+jay)
At this point a windows error message box opens with the following message:
"myfun.exe has encountered a problem and needs to close.  We are sorry for the inconvenience."
Note that without the debug option the program runs OK.
Any idea on what causes the problem and hoe to resolve it?
(7,820 Views)
Hello Farshid,
Did you see this same behavior in 7.14 or any previous version? Have you been able to reproduce it with other computers? Does this happen with any lnx program?
Thank you
Ricardo
(7,797 Views)
