MATRIXx
Memory Required problem on MatrixX System Build
When using MatrixX system build and trying to view a superblock or do some other operation, I get the message System Build Memory Required/Current where the current is less than required. How can I fix this problem.
(9,634 Views)
Pavan,
First thing to check is if the SystemBuild Memory Required/Current make sense for your computer. What are the values reported for required and current? How much memory is installed in the computer?
Also, on what operating system are you getting this error?
(9,634 Views)
Required is 233238 and current is 233000. The computer is a SParc running Solaris 2.51 and it has 256 MB of memory. The sys admin said there aren't that many users on the system. He also checked the temp and swap space and both were around 600K. Any ideas?
(9,634 Views)
Which version of MATRIXx are you running under Solaris 2.51?
Marcus Lites
MATRIXx National Sales Manager
Ph: 972-742-8353
Em: marcus.lites@ni.com
(9,634 Views)
Marcus, I'm using MatrixX version 5.0 on Solaris.Hope that helps.
(9,634 Views)
In version 5 I think you can set memory size, e.g.
(all one line, may display here as wrapped. Also this system seems to want to insert an extra space in "istack"):
build {rstack=1000000,cstack=1000000,sstack=1000000,istack=1000000}
Back when we used version 5 we would put the above in our startup.ms file. Maybe that will help.
(9,634 Views)
Don't know your name but thanks - that worked perfectly. Appreciate the help.
(9,634 Views)
