MATRIXx
Releasing a checked out license
After checking out a floating license (e.g. Control, Optimization), how does one release the license so that it becomes available to other users?
(7,681 Views)
Depends on what license it is. To release the SystemBuild license all you need to do is to close SystemBuild. For Xmath or Xmath modules (such as Control or Optimization) you need to close Xmath. Once you close Xmath the license is released.
Carl L
(7,681 Views)
There is no other way then to completely close xmath? A command similar to "licensecheckout" so that you can continue working (without having to close everything and start again)?
(7,681 Views)
There is no other way to release the license. You would not necessarily have to disrupt you entire session as you could quickly save all variables (and models) to a temporary file and then close xmath. After reopen Xmath you can then load the temporary file and continue from where you left off.
Carl L
(7,681 Views)
