MATRIXx
Running 2 Xmath sims simultaneously
Is it possible to run 2 MatrixX simulations simultaneously at different rates and have one simulation feed data to the other?
(7,955 Views)
In the AutoCode manual, it does support multi-rate applications using double-buffering between the different-rate loops. This is between two different subsystems. I will ask around if there is other documentation about this in System Build.
Richard
Richard
Field Sales Engineer, New Jersey
(7,947 Views)
