MATRIXx
SH68-68-D1 and SH100-100-F Electrical and Mechanical Specifications
I am looking for the voltage rating for the SH68-68-D1 and SH100-100-F cables. Any help would be appreciated.
(9,349 Views)
Hello Janggo,
I am looking into the exact maximum voltage rating for both cables.  I know that all the cables are capable of handling the maximum voltage of all the DAQ cards that we sell.  Almost all of the DAQ cards have an over voltage protection specification and these cables should be able to handle at least if not more voltage that is outlined in that spec.  If you send more voltage into a DAQ card then it can handle you will probably destroy the DAQ card before the cable.
How much voltage do you want to send through the cable?  What DAQ board are you going to be using in your application?
Respectfully,
Rob F
Test Engineer
Condition Measurements
(9,326 Views)
