MATRIXx
Support for IE viewing help-files in future release?
Will there be support for Internet explorer in future releases to vew help-files? Today I have to start IE, open the help-files (help.html) and then browse through the links. I would prefer to call (or search) for help from xmath and that possible matches are opened in IE.
The reason why I would like to use IE is that our computer support only permits us to use IE 5.0 as browser.
/Torbjörn
(8,262 Views)
Yes, IE will be supported in future releases. The current NI released (June 2003) and now shiping version 6.3.3 supports IE for HELP. See release notes below.
Regards;
Marcus Lites, MATRIXx National Sales Manager
Phone: (972) 742-8353
Email: marcus.lites@ni.com
MATRIXx 6.3 Release Notes
Welcome to release 6.3 of MATRIXx(R). New enhancements include:
* Consists of MATRIXx v6.2 with big fixes and minor enhancements (see below)
* 100% Xmath/SystemBuild save file compatiability (no format changes)
* Installs and executes correctly on Windows NT/2000/XP.
* Built with Microsoft Visual C++ v6.0(sp5);
MATRIXx v6.2 used Microsoft Visual C++ v5.0
* MATRIXx software CD and MATRIXx documentation CD combined onto one CD.
* Added Xmath 'Help' pull-down menu item 'MATRIXx Bookshelf' which brings
up Adobe Acobat Reader with an initial document allowing easy navigation
to all MATRIXx documentation PDF files.
* (PC Only) MATRIXx online help now requires Internet Explorer instead of
NetScape 3.01.
* Native PC hardcopy improvements for the Xmath graphical window and
SystemBuild diagrams.
* Improved Xmath 3D plots, HOOPS lighting feature enabled
* Improved cutting/pasting in Xmath Command/Log/Error windows.
MFC EditCtrl changed to use the MFC RichEditCtrl.
* All files for the PlugNSim product have been removed from the V6.3 CD
Xmath Bug Fixes
* (PC only) Online help now uses Microsoft Internet Explorer instead of
Netscape Navigator.
* Fixed bug where matrix divided by complex scalar gave incorrect results.
* Fixed bug where Xmath would hang if there was a license error. Xmath now
displays a MessageBox indicating a license error.
* Fixed memory leak in response built-in function.
AutoCode Bug Fixes
* Corrected error in # of states used to index the UCBHOOK generation (DID 22376)
* Fixed bug where Block parameter matrix data was assumed to stored column-wise.
Autocode now handles Block parameter matrix data stored row-wise correctly.
* Fixed problem with line-splitting logic related to delim character as the
first character of the string (DID 22258)
* Fixed major bug with hardcoded parameters when the -ovfp 0 and radix 0
backdoor is used. The problem was that the 'explicit' variant of the
integer gpltype was not being translated into a GPL type; thus GPL
could not generate the value (DID 22554)
SystemBuild Bug Fixes
* Fixed crash during hardcopy of SuperBlock if editor window had not been opened.
* Generated PostScript hardcopy of STDs with SuperBubbles would only print first
two pages, and would not print all nested SuperBubbles.
* Hardcopy timestamps now have a 4 digit year timestamp.
* SystemBuild blocks with 32bit bitmaps now correctly generate PostScript
hardcopy.
* %vars for vector of REAL PARAMETERS in UserCodeBlock was transposed.
* Constant block with radix not equal to 1 caused incorrect typecheck result.
* Block Dialog for ConditionBlock multiplies the number of input and output by
10 for undefined procedure SuperBlocks. The Block dialog now displays the
correct number of inputs/outputs for undefined Procedure SuperBlocks.
* (UNIX only) SystemBuild now displays color on workstatations with 24 bit
graphics cards.
* (UNIX only) SystemBuild now displays color on 8 bit workstations even though
other applications have allocated all the systems colors.
* Read/Write var blocks with logical arrays with element addressing did not
return correct results.
* Documentation TAB in block dialog did not save entered MinimumValue,
MaximumValue and Accuracy values in all cases.
* Sim results in some cases did not match after making part of the
Model a Component.
* Large BlockScript expressions did not compile correctly.
* RenameSuperBlock SBA command did not rename SuperBlock _makesb.
* General Express block would remove parens for the case: A arithOp -B;
* In Gears integration algorithm, fixed interpolation function and fixed
a few minor errors.
* SystemBuild Simulator would crash when invalid args were passed to
the InteractiveAnimation UserCodeBlock usria1.
* (Windows 2000/XP only) Altia UserCodeBlock ucbaltia1 would consume all
system CPU resources during animation.
(8,261 Views)
Exactly what I wanted to see!
It seems to me that you are on the right track with the development of MATRIXx. A year ago I thought the product was dead. But you proved me wrong. Good news for us users who have invested a lot in models for simulation using MATRIXx/SysteBuild.
/Torbjörn
(8,261 Views)
In the current NI shipping version 6.3.3 when you click on "Help" "Topics" the IE browser will be opened.
MATRIXx version 6.3.3 is available for MS WinNT4, Win2000 and WinXP. The latest version is availabe to all SSP (Software Subscription Program) customers. A Solaris 2.8 supported version will be released very soon.
The next version to be update and released will be MATRIXx version 7.0 updated to 7.1 bay year end.
Regards;
P: 972-742-8353
E: marcus.lites@ni.com
http:\\www.ni.com/matrixx
(8,262 Views)
