MATRIXx
autocode
When I try to autocode my model in 8.0(eval copy), after it finishes generating the RTF file it stops because of a "memory allocation error" .  I use all the default autocode settings.  This same model autocodes perfectely fine in versions 7.1.5 and 6.2.2.    Any ideas why?  Thanks.
(8,856 Views)
Hello SLsim,
Sorry for not noticing your post earlier, have you found any steps to be able to generate code for your model since you last posted?  In order to figure out what exactly is going wrong in this case it will help to have some more details about your model.  Are you able to post this model or another small model that reproduces the behavior?  Are you able to generate code for any models?
Also, it will be helpful to know more precisely how far you are getting in the code generation process.  Do you see the autocode banner before the error or not?  Can you SIM this model?
Thanks again for your reply, I hope with some added details about your model we can better determine why you are seeing this error.
Angela M
(8,818 Views)
