MATRIXx
fuzzy logic block debugging
I have a populated a fuzzy logic block instance in MatrixX with application data that seems consistent with the example code contained in the user's guide (e.g., membership classes, rules, etc.).  However, when I sweep the inputs through their ranges the fuzzy output never changes.  Any suggestions on how to find the problem?
(9,083 Views)
One thing to check is the members.  Do a uifuzzy {blockid=blockid} and see if you have your members assigned correctly. Are you using qualifiers?
Do you have a rule for all the possible inputs?
I would first run the code that comes by default with the block.  Check the members and then start playing with the input.
For example, you can create a time vector of t=[0:0.01:10]; and then the input to be in=random(t);
Try that and check what you get when you change the value of in.
Hope this helps.
Ricardo,
(9,066 Views)
Thanks for the advice.
I incrementally changed one thing in the generic model at a time, and the problem appears to be that I assigned an output range outside of 0 to 1.  As soon as I normalized all of the output values, the output started changing.
I tried to invoke the uifuzzy tool, but it crashes with an index out of range error in the Xmath window any time I invoke it.  Do you want me to report this somewhere?
(9,051 Views)
If you could upload your fuzzy block here and I will check it. What version of MATRIXx do you have?
Ricardo
(9,037 Views)
