MATRIXx
how can i concatenate two matrices?
(12,409 Views)
To combine matrices, you can define a third matrix where the components of the third matrix are defined with the previously existing matrices.  For instance:
A=[1,4;5,7]
A (a square matrix) =
1 4
5 7
B=[6,9;10,8]
B (a square matrix) =
6 9
10 8
C=[A;B]
C (a rectangular matrix) =
1 4
5 7
6 9
10 8
I hope this helps.
Angela M
Product Support Engineer
(12,408 Views)
Thanks Angela,
i would like to perform this concatenation using lab view
could you help me ?
(12,395 Views)
Hello rasha,
I am sorry for any confusion, questions about LabVIEW should be posted to the LabVIEW discussion forum.  MATRIXx is a different National Instruments product.  You can see all of the National Instruments forums here.  The LabVIEW forum is here.  I would recommend searching the forums and LabVIEW help for concatenate matrix or concatenate matrices.  Note that several of the functions in the array palette can be used with matrices.
Hope this helps,
Angela M
(12,386 Views)
