MATRIXx
output connection list
How do I get the output connection list of a block? I could not find it in the documentation. I can get the input connection list with the �connections� keyword with the following command:
[conn=Connections] = queryblock("TEST4")
But how do I get the output connection list? The queryconnection command seems to only give in return the external outputs...
Thanks!
Charles-Antoine
(7,480 Views)
Charles-Antoine,
Here's an .msf that should work for you. Documentation is a little rough, but you'll get the idea.
Chris
(7,480 Views)
