MATRIXx
plot2d and EMF file output
When I use the plot2d file option to create an EMF file, I get a black box around my plot.  Is there any way to prevent Matrixx from adding the box?  I don't get the box if a do a copy from the plot window file menu.
Example:
plot2d(x,y,{file="plot.emf"});
(8,776 Views)
Hi Ron,
I know if you set some of the plot settings like box=0 then you can create a Plot that does not have the black border format.  I haven't found a specific function that sets the border  but there may be one.  What plot settings have you tried currently?
Steven B.
(8,763 Views)
Steven,
The box option just controls the box that the plot is drawn in.  The box that I'm having trouble with is the black border around the entire page.  I've looked through the help, but nothing seems to control it.  It appears to be an EMF "feature".  None of the other plot formats have this border.
Ron
(8,757 Views)
Ron,
I looked through the help as well and did not find a setting for this as well.  Just to be sure we are on the same page would it be possible for you to post an image of the black box you are referring to.
Steven B.
(8,736 Views)
