Machine Vision
10 bit LEOPARD IMAGING camera
Hi
I am trying to display an image from a usb3 camera LI-USB30-OV7251 in the data sheet
they say it has " 10-bit RAW data output" how can I display it correctly in IMAQ ?
when I try it with NI_MAX it displays it as packed 8bit data (very green)
does anyone have experience with this ?
Thanks in advance
(2,331 Views)
Generally, if the camera puts out a raw image, the next step is to convert the image to an array, reshape the array to conform to the pixel format, then convert to an image.  with a monochrome camera, this is pretty straightforward.  Have not done it with a color camera yet.  And I have no experience with a LEOPARD camera.  The manufacturer may be able to provide and .icd file that tells LabView what to d with the information.
Im lazy and require cameras to meet GenICam, standards, makes life much easier.
Best of luck
Robert
(2,198 Views)
