Machine Vision
Seems I tried that and Delete was not an option. I'll look again next time I'm at the job site.
Bob
Message 11 of 21
(2,500 Views)
Still getting the same errors. To fix, close camera VI, open Network connections window LAN or high speed internet connection is called “camera”W/ admin privileges  rt clik to Disable / rt clik to enable (goes out & gets address off camera)
Open & start Camera.vi…
At another time, power went out, our system stayed up with UPS but lab network went down. Camera went with it !!  Disable/enable did nothing until main network came up after lunch.  Erratic camera connection definitely tied to LAN operation !
Any comments or ideas?
Bob
Message 12 of 21
(2,481 Views)
Oh, so this is through the lab LAN? What happens if you connect it directly to the computer with a crossover?
Jeff | LabVIEW Software Engineer
Message 13 of 21
(2,471 Views)
No, the camera is connected to a port on a GigE card and the lab LAN goes to one of the built in ports on the PC.
Bob
Message 14 of 21
(2,468 Views)
If you leave the LAN connection disconnected does it work (perhaps reboot with only the camera connected) consistently?
Message 15 of 21
(2,434 Views)
I used the same system during software development without the LAN connection and never had this problem so it seems to have something to do with the LAN connection although it goes to a totally different interface. We'll have the IT people take a look but I don't hold out much hope of them finding anything.
Bob
Message 16 of 21
(2,414 Views)
Bob,
Can you do an "ipconfig /all" and "route print" from the command line (in the non-working configuration) and paste the results here? You can append "| clip" to pipe the results directly to the clipboard for easier pasting.
I suspect this might give some better idea of your network configuration and what might be wrong.
Eric
Message 17 of 21
(2,411 Views)
Eric,
Problem is that I'm not on-site. I'll see if I can get someone at the site to do that.
Bob
Message 18 of 21
(2,406 Views)
Same problem occur here, i have 2 identicals systems. (CVS IC3173 with linescan racer gige camera)
One run without any error over days, the other constently have a timed-out problem or a camera remove problem... In this situation, I reset the camera and reconnect to it and continue but that is a problem, we test the cables.
-1074360308 or -1074360293
error log :
Wed 09 Nov 2016 09:21:41 PM EST -1074360293
Wed 09 Nov 2016 09:25:46 PM EST -1074360293
Thu 10 Nov 2016 12:20:03 AM EST -1074360293
Thu 10 Nov 2016 12:51:42 AM EST -1074360293
Thu 10 Nov 2016 01:32:33 AM EST -1074360293
Thu 10 Nov 2016 02:14:01 AM EST -1074360293
Thu 10 Nov 2016 02:16:56 AM EST -1074360293
Thu 10 Nov 2016 05:39:59 AM EST -1074360293
Thu 10 Nov 2016 05:41:16 AM EST -1074360293
Thu 10 Nov 2016 10:17:47 AM EST -1074360293
Thu 10 Nov 2016 10:19:22 AM EST -1074360308
Message 19 of 21
(1,774 Views)
Been a long time ago, but I think the problem had something to do with the network program looking for a server. This was a lab system and intentionally not connected to a network. It was an IT problem and they finally resolved it.
Sorry I can't be more specific, the lab has since been sold and the guy I was working with at the time has unfortunately passed .
Bob
Message 20 of 21
(1,767 Views)
