Machine Vision
1409 for Progressive CCD
Hi sir:
I have 1409 vision Card use in get Non-interlace CCD
but I can't get clear Image .
1. I use MAX to configer 1409 CH0 30 Hz Progressive Scan, 640x480.
2.I setting CCD to Non-interlace mode.
3.I Grab Image in MAX.
4.I got the Image not clear.(see the Attach Files)
How can i do, I need your help me
Thanks.
vovo
(2,999 Views)
When I opened your image in Vision Assistant the image looked pretty clear with a bit of noise in it. If that is the noise that your talking about, this may be caused by low light levels and the camera's auto gain control.
If the problem is you can't see the picture clearly when opening it in Photoshop or some other Photo utility, then the problem has to do with the way we store 16 bit PNG images. To get around this you could set the 1409 to 8-bit mode if you don't need more than that. The following KB will give you more information on this known issue.
Why Does My 16-bit PNG Image Saved Using IMAQ Vision Appear Black in Photoshop or Photo Editor?
Doug K.
Application Engineer
(2,998 Views)
