Machine Vision
16bit to 8bit image conversion vb
I am trying to save an image as a jpeg.  To do this I need to make the image 8bit.  This is one line in the sub to convert the image.  I get a "Runtime error 5.   Invalid Index"  How can I overcome this.  Is there a better way to do it?
CWIMAQVision1.Subtract Image, HistogramReport.Item(0).PixelRange.Min, Image
(4,503 Views)
Although not Visual Basic (although there are references to it), I posted a similar question earlier. See the thread on "C and LUT", http://forums.ni.com/ni/board/message?board.id=200&message.id=8720
Message Edited by Harold Bien on 02-01-2006 02:03 PM
[System info: NI-1429e running in 'Base' CL-mode plugged into an x4 PCI-e slot on a Dell PowerEdge 1800, dual 3.2Ghz Xenon, 6GB RAM, Windows 2003 Server SP1, LV8.0/7.1, IMAQ v3.5, Dell CERC SATA RAID controller card with 4x250GB Seagate HDD, one Seagate 250GB HDD connected to system's primary SATA port for OS.]
(4,482 Views)
Whoops, sorry, dunno how to delete that above msg. Ignore it - it's not really relevant...
(4,460 Views)
tres0422,
Was this problem fixed by the solution in your other thread?
Ryan F.
(4,131 Views)
Ryan,
   Yes sir and thanks for following up on this thread.  Should I post the code for future users?  I will admit I am an amature so my code is not the  most efficient but it got the job done this time.  Thanks again for your help.
     Thomas
(4,126 Views)
No problem.  The code is probably unnecessary in this thread.  For my edification however,  I would be interested if you would post the final working code in the other thread.
Ryan F.
(4,119 Views)
