Machine Vision
2D barcode reader how to get suggest value
hi,
      i am using labview 2015 and vision assistant 2015.i try get all setting what are all show in vision assiatant but i can't able to get suggest value button  functionallty.
     when i click in Vision assiatant this button it automatically adjust the settings value. but when i convert into vi.this button option not showing.how can i use this button in vi code.
(4,946 Views)
I have looked at this function and could not find it as you already mentioned. I believe there is a loop running on Vision Assistant, which tries values and suggests fastest parameters. So, if someone share the algorithm behind that, we can create such a function.
(4,910 Views)
hi,
       me also think same.how to run the loop and which are the parameter can i increment ,decrement.
(4,902 Views)
Here is some code that can be used to suggest datamatrix parameters, similar to what Vision Assistant is doing behind the suggest values button. I am attaching a zip file that contains 2 VIs. The main VI you want to use is "Data Matrix Suggest Values.vi".
Hope this helps. Let me know if that works for you.
Christophe
(4,868 Views)
 Hi Christophe,
I came across your VI posted for Data matrix suggest values. But I am getting an error constantly when I pass my image and ROI.
Error -1074395635 occurred at IMAQ Read Data Matrix Barcode 2m
IMAQ Vision:  The passed shape descriptor is invalid.
the ROI being passed is a rectangle. I have 34 barcodes in a single image and trying to decode them all.
I need a solution for this very badly. Appreciate your help!!
(4,383 Views)
Hi..anyone who can suggest a solution for this.
(4,361 Views)
Hi, I just got this error like you when I tried to inspect a DataMatrix Code: the passed shape descriptor is invalid.
On the Barcode Size Option, I reduced the minimum size of the bacode to 0 and the maximum to 1000.
Good luck
(3,274 Views)
