Machine Vision
3 colour ccd camera
I have a 3 colour ccd camera (Y/C output)Hitachi HV-C20AMP. What acquisition card should I use and has anyone else implemented this.
(3,074 Views)
The output signal is composite PAL and the connector is BNC. The 1411 can acquire PAL. If you want to set camera attributes you have to use the serial port of your pc and may be a Hitachi software. You can find a manual for the 1411 at (http://digital.ni.com/manuals.nsf/display?ReadForm&lookup=Machine%20Vision%3E%3EAnalog%20Image%20Acquisition%20Devices&view=web_productcurrent&node=132090_US).
(3,074 Views)
