Machine Vision
3 dimensional pose estimation
Hello!
I am trying to develop an application wherein I want to identify and locate(determination of the dimension and orientation of a 3D object w.r.t a particular reference frame) a 3D object in any pose. What is the correct approach for such a problem? I am new to LabView, so any kind of example or links to reading materials will be helpful.
Thanks...
(3,266 Views)
Hello 82822,
You could start by looking through the Vision Concepts Manual.  You can find that document here:  https://www.ni.com/docs/en-US/bundle/ni-vision/page/user-manual-welcome.html .  It has a lot of useful information on different kinds of images processing.
You could do a simple pattern match to recognize the object and then use the coordinates of the object that the pattern match finds to define the object's location.
Michael B.
(3,255 Views)
