Machine Vision
3D Vision options for LabVIEW?
What type of 3D vision options do I have with LabVIEW?  I would like to be able to use 2 cameras to track movement in 3-space at a rate of at least 10 Hz.  If I can not do this with LabVIEW, can someone recommend other products that might help me accomplish this?
Dave
(3,356 Views)
Hi Dave,
LabVIEW is easily able to acquire from two cameras at the same time and if programmed correctly is able to track individual objects within it's field of view.
Therefore if you use 2 cameras (90 degrees from each other) looking towards the object then it will be possible to track the movements in 3D.
Once you have the 3D information it is possible to plot the object inside a 3D graph or better still inside a 3D picture control.
Is this the information you wanted?
Regards
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,353 Views)
